2001 escort
rloya99
06-30-2007, 11:06 PM
i have 2001 escort that when u let car sit for while it is hard to start it take about 2 cranks before it starts i chance the throttle position senstor i no luck i also chane the idle air control valve no luck any advise thank u
GTP Dad
07-01-2007, 01:14 PM
Check the fuel pressure when the key is on. You may need to change the fuel filter or the fuel pressure sensor. It sounds like you are getting some leak down when the car sits. One way to avoid this would be to turn the key on for a few seconds and wait. This will build fuel pressure and it should start readily.
Davescort97
07-01-2007, 01:22 PM
The fuel pressure regulator might be bad. It is a diaphram with a vacuum hose running to it. It is on top on the L side of the engine. Close to the fuel rail. If the vacuum line has come lose or is leaking you won't have pressure held in the system.
rloya99
07-01-2007, 05:00 PM
thank u
