preparing my car
PlayStation3
06-30-2007, 03:11 PM
hi, ok so i decided to use a 12" re audio XXX for my substage and since it needs 2k watts and my amp for my speakers is 500 watts( i'm upgrading to a more power 4 channel amp) so that will 2.5k watt system now things i have done to my car so far is the foloowing: 1/0 guage big 3, 200 amp alt ( biggest they make for my car so i can't really get bigger without losing stuff like power steering etc) now i figure i will add a second battery in my trunk but my question is this. if i run 1/0 gauge from the alternator to the isolator then run 1/0 guage from the isolator to the battery that will have the amps attached to. then if possable could i run 4 guage wire from the isolator to the battery that will be under the hood that has nothing in terms of audio done to it. and could i run a starter battery under the hood and either a yellow top or a kinteck battery in the trunk
PaulD
06-30-2007, 06:22 PM
I have to say I have never had the need to have a 2nd battery.
NAVY IC
06-30-2007, 08:56 PM
same here...
PlayStation3
06-30-2007, 11:31 PM
yea i know but i like to cover my ass just to be safe. and i might do some type of amatuer competion with this set up. and since i hear most are with the car off then it would be nice to be able to start my car with out being jumped
PaulD
07-01-2007, 09:35 PM
most are with the car ON unless you compete as an actual amatuer. I wouldn't worry about it until you install the stuff and find out you're electrical system isn't up to par.
PlayStation3
07-01-2007, 10:30 PM
ok cool because i am getting second thoughts on having a XXX versing like 2 12's being fead the same amount of power.
jakeachy
07-01-2007, 11:58 PM
schoshe or stinger makes a battery for exactly what you are talking about, buy unless you are running an Immortal sub, you dont need it...
PlayStation3
07-02-2007, 12:18 AM
i hear kinetik is better battery. and by buy do you mean but
