Engine Turns, Has Spark And Gas Wont Crank!! Please Someone Help!
95acura87
06-27-2007, 07:36 PM
:banghead: ok i have racked my brains trying to figure this one out: I just recently was givin a 94 Eagle Talon 5 spd 2.0L DOHC with 130,000 on the odometer the man i got it from said it ran 3 months earlier and then just quit I had a new timing belt, crank angle sensor , new plugs and wires put in and it wont start. It turns over it's getting gas and spark but just wont start i dont know what to do i had a dealership put the timing belt and the timing belt is fine the sparkplugs are firing, the injectors and the fuel pump and everything else works but it wont start it just turns over if somone has any suggestions that would maybe help me i would greatly apprecieate it
spyderturbo007
06-28-2007, 07:11 AM
Does it have compression? Have you check the ECU for leaking caps? Just remember, you might have spark and fuel, but they have to be in the correct amounts / intensity for the motor to fire.
pollitoeclipse
12-10-2010, 10:08 PM
hi i have the same problem on my 96 talon i was wondering if u have figured out the problem with ur car.. am about to give up on my car:runaround:
SilvrEclipse
12-10-2010, 10:39 PM
Welcome to AF. This thread is 4 years old and these guys dont even get on here anymore. Post up a new topic with your problem and maybe we can help you out.
pollitoeclipse
12-10-2010, 11:11 PM
i have the same problem do u think it migth be the crankshaft sensor i have change almost everything ..ecu spark plugs cables cam sensor fuel pump and am getting fuel and spark but dont start also has a new timing belt....crankshaft sensor is the only thing i havent check
