injectors
turbo2nr
11-01-2002, 10:53 AM
will upgrading fuel injectos burn alot more gass than stock injectors
i no that they will burn more but will i have 2 go 2 da gastation evey 10 blocks
im talkin bout over 550cc injectors wit a upgraded fuel pump runnin 8-14psi of boost?
:confused:
J SPEC SilEighty
11-01-2002, 02:39 PM
more air coming into combustion chamber = burning more fuel.
The bigger injectors are necessarily the ones making you burn more fuel. If your adding a turbocharger then your going to need more fuel because there is more air. The bigger injectors just deliver the fuel. If you don't have a turbocharger or a lot of mods then the stock injectors work fine and you have no need for the bigger ones. But to answer your question in short, yes it will burn more gas.
