I have 2 10 inch MA Audio ma100xe subs, need amp
bamavoo
06-27-2007, 10:08 AM
They are in seperate 0.75 ci boxes. What would yeild me the best bang for the buck?
600W RMS (pr.)
1200W Max (pr.)
Dual 4-Ohm Voice Coils
110 Oz. Double Stacked Magnets
Mounting Depth: 5.6”
Mounting Diameter: 9.2”
Optimum Vented Box: 1.75 Cu/Ft
Round Port Diameter: 4” x 9”
Square Port Area: 2.5” x 6” x 11.5”
Optimum Sealed Box: 1.0 Cu/Ft
Tuning @ 40Hz
Thanks in advance!runaround
bamavoo
06-27-2007, 10:53 AM
600W RMS (pr.)
1200W Max (pr.)
Tuning @ 40Hz
I had each sub running on seperate amps.
The Verge :screwy: @ 300 watts rms and a
Profile :shakehead @ 300 watts rms
They just didn't seem to push them enough. The sound was decent, but not what I thought it should be.
The sound quality was really good, but spl was very lacking. runaround
NAVY IC
06-27-2007, 02:57 PM
how are your coils wired, series or parallel...??
bamavoo
06-27-2007, 02:59 PM
Right now they are parallel, but I can wire them series. I just want to know the best bang for the buck.
Thanks,
Just from reading around I thought you might be the one to help :)
bamavoo
06-27-2007, 03:25 PM
The Hifonic zxi6006 looks like it will do the job. It is rated at 300x2 @2ohms or 600x1 @4ohms. What would be the best way to run it? Looks like I would get the same power, but would only be pulling 4ohms by letting them run in parallel. Plus the price is pretty good on this amp as well.
NAVY IC
06-27-2007, 10:03 PM
Ok. so you're working with 2ohms per sub
and you want bang for the buck, did you check out MA amps, I mean you got their subs already...
this is the catalog on their site
http://www.maaudio.com/assets/Image/Catalog/MA_CAT_2007.pdf
this is a couple of places to buy 'em from
http://www.bizrate.com/caramplifiers/ma-audio-hk798-2-channel-amplifier--pid359239696/compareprices.html
as far as the hifonics go, you can check 'em ouut here
http://www.maxxsonics.com/hifonics/index2.html
all of these hifoncs models will work for you
the Txi6006, (Titan)
http://www.shopping.com/xPO-Hifonics-HiFonics-TXi-6006-2-Channel-Amplifier
the Zxi6006, (Zeus)
http://www.shopping.com/xFS?KW=ZXi+6006&CLT=SCH&x=37&y=11
the Bxi606 (Brutus)
http://www.shopping.com/xFS?KW=BXi+606&CLT=SCH&x=41&y=11
bamavoo
06-27-2007, 10:37 PM
the Zxi6006, (Zeus)
the Bxi606 (Brutus)
Thanks man. You surely ROCK! :naughty: :grinyes: :rofl:
