Ticking!!!!!!
brdjwm
06-26-2007, 09:55 AM
i have a 97 rodeo and it has 148,000 miles on it and it ticks constantly. some days louder than others, but it drives me crazy :banghead: . before it was just a slow tick, and now it has gotten worse and ticks very fast and sounds kinda like a disiel motor.....any ideas of what it could be and how it can be fixed? :frown:
tony4x4nc
06-26-2007, 10:47 AM
Lots of people said timing belt tensioner....when was the last time that was changed? Check my post below "really loud knocking/ timing???". I had the same noise. The noise coincided with the RPM's. as they went up the sound sped up. My timing belt had jumped a tooth or 4 and the engine lost power and turned over two-three times before it started. put a new timing belt off ebay on there(hard to line up) with only two of the 3 marks necessary for installation. Started it up and stil had the sound and timing was way off. Bought a new belt from the honda dealership (72.00) and put it on and started right up no more ticking/knocking. Athough timing doesnt seem to be quite where i think it should be the truck runs fine and the power is back and more importantly the ticking is mostly gone. A guy also told me Fram oil filters make these engines tick. I currently have a fram on there and I'm changing it this weekedn so i'll post my results. I tried seafoam, ATF in the engine, Mobil 1 Ow-30.......I guess they helped a little but the sound never completely went away. Hell of a lot quiter though! I also read about a bracket on the passenger side exhaust in front of the cat that has a round weight like thing that will cause a tick if it is broken and hanging against the exhaust.
brdjwm
06-26-2007, 11:35 AM
im not sure when it was changed but yea thats how mine does, and i have also lost a lot of gas milage....i used to get 15 but now i only get 13 and i have lost a lot of power
tony4x4nc
06-26-2007, 11:51 AM
sounds like you need t-belt and tensioner. Whhile your in there you should also change the water pump since it's right theres. 5-6 extra bolts. I would def go with a t-belt from a dealership or just verify that the one you get has THREE timing marks.!!! Very hard to align without it
tony4x4nc
06-26-2007, 11:54 AM
Lots of sites said to remove radiator and hoses while doing this...I opted not to and had ample space to maneuver. Was easier for me to cut a piece of plywood and mount it behind the radiator to keep from damging it. But if your hoses r bad you might as well change them too. All together the job cost me bout $220. Just post if you run into any troubnle
Ramblin Fever
06-26-2007, 07:36 PM
DEFINITELY change as many coolant hoses as possible - this coming from someone with the same age truck as both of you two, specially the heater core hoses, trust me they're shot!
