thunderbird 96 turn signal/brake lights out
drgonzo156
06-24-2007, 04:59 PM
I have a 96 t-bird, the turn signals and brake lights both went out at the same time. Then a day later the battery dies. Now even fully charged the volts are running low on my meeter. All the fuses are fine but I can't find the flashers. However the hazard lights still work.... any ideas?
97Bird
06-25-2007, 07:26 PM
If the lights still flash when the Hazard switch is activated but you have no brake lights or turn signals then it sounds like you have a bad multi-function switch. Have the battery and alternator tested at your local AutoZone or equivalent.
