SS/SC springs on LS coupe
Black07LS
06-16-2007, 09:42 AM
How much will SS/SC springs lower my LS coupe?
-Jayson-
06-16-2007, 10:42 AM
i dont believe you can do that, the SS Supercharged has an entirely different suspension setup than a base model
Hinshawwrx
06-23-2007, 01:32 AM
Wrong
You can do it and many people do. The advantage isn't crap however. You drop about half an inch to 3/4 of an inch, if your looking for a good drop this is NOT the answer.
The only difference between the SS and LS suspension is that the SS has bigger sway bars, different front struts, and different springs. EVERY single mounting point is the EXACT SAME for each model.
This also applies to EVERYTHING else in the car, all the mounting points for SS components are on the LS car, the components are just not installed. This means you can easily put everything from an SS onto an LS. Its a "Cookie Cutter Car"
Wrong
