1992 c/k 1500 2wheel drive swap
tyflesh
06-06-2007, 12:25 PM
i have a 92 c/k 1500 2wd ext cab that i want to swap out parts off a 99 tahoe i wanted to swap the engine and trans and possible the rear end if need be, i wanted to know if anyone has any suggestions on any problems i might run into with this project, i also wanted to swap out the dash and all its contents, like gauges and front seat. thanks for all you guys help.
MT-2500
06-06-2007, 01:14 PM
Lot of changing may get it.
Also fuel tank and fuel pump setup.
And the exhaust setup with the 02 sensors.
The 99 will have a anti theft built into VCM/PCM so you may need the steering wheel and ign stuff and body pcm from the 99.
Also read . and check you local and state regulations on engine swapping.
http://www.epa.gov/air/caa/caa203.txt
MT
MT
tyflesh
06-08-2007, 12:22 AM
MT
thanks MT i didnt think about the steering column and the steering wheel but i was going to swap the fuel tank and the pump, thanks again
MT
