Fuel Sending Unit Broken Gas Gauge Fix
awnicol
06-05-2007, 10:42 PM
If your gas gauge is not working and you may have a check engine light on as well then you need a new fuel sending unit. Dealers may tell you that you need a new fuel pump and that a fuel sending unit is not available for your vehicle. However, this is not that case. I have Isuzu OEM/Factory fuel sending units that will fit any Rodeo and Passport from 1998-2002. You will not need to recalibrate anything and it should cost no more than $150 to install, or you can do it yourself in under 2 hours! This unit WILL fix you problem. Do not let the dealer rip you off! I fixed mine in my 2000 Rodeo 4x4 and figured I may as well help others out and save other hundreds of dollars. My item is for sale by calling Andy at (407) 625-4295 or [email protected] or by looking on eBay.com for Seller awnicol25. Good luck! Save some money!
AWILLIAMS64
06-07-2007, 02:44 AM
i can vouch for this guy, i bought mine last year from him and it worked great!!!
2eyefishclaw
06-08-2007, 12:12 AM
Not Everything He Says Is True Yes The Sending Unit Will Fit However On The 98 Model If Your Pcm Has Never Been Updated You Will Need To Have This Done For Proper Operation Of The Sending Unit
I Am An Isuzu Tech And You Can Purchase This Same Sending Unit From A Dealer For Around $56 And If You Have Proper Equipment It Can Be Installed In Under 10 Minutes
