Help with keyless entry (96)
Vistopher
06-03-2007, 02:01 PM
So a few months ago I bought a '96 park avenue, and there was no remote for keyless entry. Where would I obtain a remote, and how would I go about programming it?
Thanks.
HotZ28
06-04-2007, 07:04 PM
You might try your local JY, or Ebay for the remotes. Be sure to check the user feedback on Ebay! Once you find a source for the remote, Click Here (http://programyourremote.com/) and enter make and model of your car for programming instructions.:icon16:
Onblsht
06-06-2007, 10:08 PM
Transmitter programming per the GM manual:
Important:
Before entering the programming mode, verify the possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases the other transmitters. You may program up to 4 transmitters
1) Turn OFF the ignition switch
2) Usa a fused jumper (3 amp is sufficient) and connect terminal 8 (back/white wire) to terminal 4 (black wire)
3) Close all the doors
4) Turn ON the ignition switch
the doors will lock
5) Press and hold the following buttons on one of the transmitters for 30 seconds:
lock and unlock
6) After a 30 second delay, the doors will lock and unlock
Important:
DO NOT turn OFF the ignition . If the switch is turned OFF the first transmitter becomes inoperative.
7) In order to program extra transmitters repeat Step 5
8)Disconnect the fused jumper wire from the data link connector
9) Turn off ignition
10) Verify functions of all programmed transmitters.
