octane HELP!!!
shming123
10-25-2002, 07:33 PM
hey, i just got a B16B engine from japan, and i know in japan they run 98 octane...do i need to get a different ECU or something? Will it run on 91 octane OK without hurting the engine?? thanks/ or do i need to do something with the ignition??
b16a3sol
10-26-2002, 01:35 AM
you should be fine running premium. the compression is only .2 more than a b16a from here in the states. and also, not everyone in japan uses 98 octane. just cause its available, doesnt mean they have to use it.
sameintheend01
10-26-2002, 01:32 PM
Also, in europe, the way they calculate the octane is diffeent. There si a conversion somewhere. A lower octane American gas is comparable to a higher octane european gas. Maybe in Japan these use a different calculation also.
gemballa
10-26-2002, 05:44 PM
it will always hurt the engine because the comprssion!
they cumbustion chamber will not be refreshd the same way with a 91 octane gas!
you should go for airplane gas that haves 100octane!
