2000 escort fuel pump not working
utinni
06-01-2007, 05:45 PM
First off, thanks to everyone that posts here i have applied a lot of the knowledge gained here.
The double aught 'scort died a few times on me. It had electrical but the engie died. Turning off the key then back on and it started right up. That was about 2 days apart, one instance on each day. About a week after that it died on the road but would not start again. After tracing the prob back to the fuel pump, i pulled it and checked the pump motor, all was good. The inertia cut off switch was good, lines are clear. So after reading alot on the forum here i decided to check the CCRM, since the A/C had also stopped working previously. Guess what, not only where the solder points bad on the A/C relay but also on the Fuel Pump relay. I cleaned and resoldered the loose ones and that fixed the fuel pump problem, but not the a/c. But I think the A/C relay is totally bad and not just loose.
