02 mirage with A/C problems
mgxtek11
06-01-2007, 12:10 PM
The A/C in my 2002 Mirage works fine for about 20 min. then starts blowing out hot air. If I shut it off for about 20 min. then turn it back on it will start blowing cold air again, but only for about 15-20 min. The refrigerant level was check out and was ok. Also the system isn't leaking. When the a/c works it blows out cold air. Can anyone help me with this problem? Could this be the compressor starting to fail?
DFBonnett
06-03-2007, 08:50 AM
When it stops blowing cold air, is the compressor clutch engaging?
mgxtek11
06-08-2007, 06:32 AM
When it stops blowing cold air the clutch isn't engaging at all.
I noticed last week when it was below 90° outside that it ran a little longer before stopping. (20-25 min.)
If the compressor was bad wouldn't it not work at all? When it does work the air seems very cold.
