Gas pressure build up,comes out of filler
Tim the tool man
05-30-2007, 06:17 AM
replaced fuel pump,every time I put gas in jimmy,pressure starts to build up
and leaks out of the fiiller,also was running rough,let the pressure out then was running ok until it builds up again,go figure
aleekat
05-30-2007, 07:04 AM
Sounds like your vent in the gas cap is plugged.
MT-2500
05-30-2007, 09:08 AM
Welcome to AF.
What year and engine?
Inside the filler tube is a smaller hose that works as a vent for filling up.
The small hose inside the big hose is off inside or pinched.
Where did you disconnect the filler hose when replacing fuel pump?
MT
Tim the tool man
06-06-2007, 04:40 AM
Welcome to AF.
MT Hey, thanks for the reply,its a 95,4.3 vortex.I disconnected the hose from the gas tank.it also has a small vent hose next to the filler hose.
MT-2500
06-06-2007, 08:57 AM
If it has the outside vent hose up to the filler cap check it for kinks or being stopped up.
If it is not filling up good it is not venting good someplace.
MT
