keyless entery
masterp
05-25-2007, 04:02 PM
Hey I have another question,
I the alternator went out on my 1997 2.4 grand am. I took it to the dealer(yeal I know expensive but I though it was the computer) and they fixed it. Now that I have it back the keyless entry buttons on my key chain will not work on the doors or trunk. Do you have any ideals?
masterp
05-25-2007, 04:35 PM
guys i was going to try to program it via instruction left in the forum. I dont understand what to do can one of you help.
It says:
1. Turn OFF the ignition.
2 .Jump the 2 terminals (3, 4) in the program ground connector, in order to ground the receiver program terminal. Left front of the luggage compartment right below the keyless module.
3 .Within 2 seconds the following sequence will occur, signalling that the module is ready to be reprogrammed:
The rear compartment lid release cycles.
The horn chirps.4. Press and hold both the lock button (5) and the unlock button (2) until the signalling sequence occurs (approximately 12 seconds). The sequence indicates that the transmitter has been successfully reprogrammed.
5. Repeat step 4 for the remaining transmitters.
6. Remove the jumper from the terminals in the program ground connector.
7. Verify that each transmitter operates properly.
:screwy: :screwy:
question, first, where is the program program ground connector located, i know you said in the luggage compartment, but is that the trunk,? If so i did not see it, also does jump mean to hook a wire to both terminals? i know you saying this boy is dumb as a rock, and it is true, that is why i need your help
masterp
05-25-2007, 04:48 PM
hey i found a black box that says remote fucntion admission modual, is that it and please explaine how to jump 3 to 4
xeroinfinity
05-25-2007, 10:51 PM
I have no clue , but did you see if it was just the battery ?????
Most likly since it was programed before it should not have been unprogramed :grinno:
If that box says is the remote modual then their should be a port with tiny mubers showing what they are, then you just the one's stated above. I've not had to mess with many remotes so I'm not certain.....
