No power to radio deck/dome light.
NightWear
05-22-2007, 02:16 PM
my domelight fuse needs to be replaced i think. However i'm not sure where it's located. I believe it's under the hood. I own a 1996 Isuzu Rodeo. I believe it's a 15amp fuse that i need to replace. My dash radio and domelight are out, i was told that they operate using the same fuse.
15Amp Fuses under the hood:
EB-1|Hazard
EB-12| ECM
EB-13| (ABS)
EB-14| ABS H/U)
Incase it's helpful since my radio is a 10Amp here are the 10A fuses:
EB-2| HORN
EB-8| H/Lamp -LH
EB-9| H/Lamp -RH
PaulD
05-22-2007, 06:16 PM
the radio fuse is usually under the dash
NightWear
05-22-2007, 06:40 PM
So the radio ruse controls the dome light also? I know wher ethe radio fuse is i've changed it for a fuse of the same amp, the power doesn't doesn't go on though, and my handy DMM isn't picking up any volts. Tiss a bit iritating. trying to find what the problem is exactly, no luck yet though.
And1fixer
05-23-2007, 08:54 AM
it would probably be better to post this in the Isuzu Rodeo forum
PaulD
05-23-2007, 04:31 PM
there is probably another fuse under the hood too, follow the wires from the + side of the battery - one should follow to the fuse block
