Just a couple questions
Dodge Stratus
05-22-2007, 04:27 AM
Im getting 1 kicker cvr 12'', with a kicker solo baric box. Im not sure what kind of amp to get. I know the amp has to have 20-50 more watts as the speakers RMS. The speaker RMS wattage is 400 max 800. Could I get a 750watt amp and not blow the speaker? I want it to beat to its full potential.
What would yall recomend? Sorry for asking dumb questions.
bjboertje
05-22-2007, 12:51 PM
you can get as big an amp as you want, you just have to set the gain right.
NocturnalCreations
05-22-2007, 01:56 PM
took the words right out of my mouth
PlayStation3
05-22-2007, 04:24 PM
actully i tryed that. i got up to 120 watts rms on a speaker rated for 60 rms.
Dodge Stratus
05-23-2007, 03:31 PM
Thanks for the help guys.
What kind of amp would suit 1 12'' the best? Im not sure on which one to get. I dont understand what this means- 4 ohms 700watts x2
2ohms 1200watts x2
and so on
so if my speaker is 4 ohms,that amp would push 700watts on x2 speakers?
bjboertje
05-23-2007, 06:05 PM
if your speaker is 4 ohms and has a rating of 500 rms you would want an amp that will push 500 rms @ 4 ohms. an amp's power is roughly doubled when you cut the impedance in half. so if you have two 500 rms subs that are 4 ohms each, you would need an amp that pushes 1000 rms at 2 ohms.
Dodge Stratus
05-23-2007, 09:08 PM
Thanks alot, that really helped out. :worshippy
Dodge Stratus
05-23-2007, 10:55 PM
so if you have two 500 rms subs that are 4 ohms each, you would need an amp that pushes 1000 rms at 2 ohms.[/quote]
why at 2 ohms?
PaulD
05-24-2007, 05:52 PM
because when you connect the subs together (in parallel) they will be a single 2 ohm load.
