95 Eagle Talon Esi A/t Has No Spark
GENE1969
05-20-2007, 04:04 AM
I HAVE A 95 EAGLE TALON ESI A/T NON-TURBO THAT WONT START UP . ALSO HAS NO SPARK. I CHANGED THE CRANK SHAFT POSITION SENSOR BUT STILL NO SPARK. NO READINGS COMING OUT OF THE COIL OR THE CAM SHAFT POSITION SENSOR.TIMING IS ALSO FINE .IT USE TO JERK A LITTLE AND JUST DIED OUT ON ME ONE NIGHT. ANY ONE KNOW WHAT MIGHT BE GOING ON ? :banghead:
david-b
05-20-2007, 11:47 AM
If there's no reading coming from the coil, I would say to change that. If you have no spark, and the main part that starts the spark has no reading, change that first. The cam position sensor may have no signal, but I don't think that would cause you not to have any spark at all. Could be wrong though.
