MELT DOWN!! Need ZC PARTS
Cfmotorsports
10-21-2002, 08:45 PM
Well this has ben just a GREAT Monday, on the way home from work this evening i hear this noise under the hood and then a screeching sound, well i can pull over i am on a very large 2 lane Damn with no burms (I have to cross a lake to get home) well i am driving along slowed down a bit hoping to make it the other side and just as i was pulling off i heard belt screeching again and then the motor cut off.
I opened the hood and just about cried, i looked down inside to see the timing cover melted down and the belt was off melted threw the cover that is and looked deeper to seel the crankpulley had also came off and broke the alternator belt.
I did have parts at home and tools is the car that i could put the belt back on limp it home.
A list of what i need from you Guys Or Gals I hope:
Upper and lower timing covers DOHC ZC
Crank Pully
What i can get local:
Timming belt
Alt Belt
Key way to set pulley in place
Crank bolt and washer
Couple ?
Is this an Interferance motor (does the valves hit the pistons when the belt brakes) I did drive the car home but could not tell for sure if it was ok.
Will the crank pully off the stock si motor work that is what i used to get home? but is it right for the motor it does look totaly differant.
where can i get these parts from if nobody on here has them?
is there a beter than stock crank pulley that I can get for this motor.
where and how much?
Thanks For all the help and info
kris
10-21-2002, 08:57 PM
Crank Pully
Timming belt
Alt Belt
Couple ?
where and how much?
If the Si pully fit, and the bolt screwed in, use it. AEM makes a lightweight pulley, up to you if you want to spend that much.
Timing belt you will need is from a 88 prelude.
Alternator belt from a 88-91 Si
Cfmotorsports
10-22-2002, 05:28 AM
Well thats what i was thinking but the pully is heavy campered to the zc pully. will it hurt anything.
kaytec4door
10-22-2002, 09:55 AM
MAN that sucks about your car. but the only thing that i have that is ZC is a head complete with cams and all valve train comp. that has been cleaned and crack tested with die, if you want it its 4 sale. i need to get rid of it.
Cfmotorsports
10-22-2002, 05:31 PM
Is the head stock, and how much ya looking to get for it.
Cfmotorsports
10-23-2002, 05:52 PM
Nobody has any parts for the zc, how about what might interchange with the ZC come on people i have faith in you help me find some covers so i can get back on the road again.
Also does anybody no what valve cover gasket i need to get for the ZC
kaytec4door
10-31-2002, 11:27 AM
yea the head is stock but it has about 115k miles on it. im asking around 80$
sastanley
10-31-2002, 11:45 AM
Valve cover gasket = 1989 Integra...just bolted my valve cover on my ZC a couple of weeks ago and it fit great.
www.acuraautomotiveparts.net
