96 lincoln continental wont start
lando423
05-08-2007, 01:12 PM
why wont my 96 lincoln continental start i had it towed for an flat tire now it wont start to save it life. It cranks but wont cacth fire somebody help me it had been sitting out in the tow yard for about 3 days and i went to start it now it won start so i dont have an clue about it . i was wanting to know if the sercuity system went off it it cause it not to start and and maybe how counld i check the fuel senor or whatever or any other ideas about my car holla back at me yall thanks email me at [email protected] or message me there or just post reply here thanks
Towncar
05-08-2007, 02:09 PM
..i had it towed for an flat tire now it wont start to save it life.
I suspect the Fuel Inertia Cutoff Switch. If the car gets bumped too hard the Inertia Switch trips, cutting off the fuel pump.
Mine's in the truck, mounted close to the drivers side trunk support arm. There's a button on there to reset it.
Reply with your findings...
lando423
05-09-2007, 09:22 PM
ight i found it but i pull it up then put it back down and it steal wont start iz it the fuel thing right beside the airbag cutoff switch because i dont know if it the right thing but yeah it got an slot where you can pull an red button up and down and it says something about an fuel cutoff switch so somebody help me out with any other things to check and i was wondering where iz the fuel pump located on my car thanks
Towncar
05-10-2007, 02:33 PM
Yep, you found the Inertia Fuel Cutoff Switch.
You need Fuel and Spark to run that engine. Do you have both?
When was the last time it was running well?
I'm not with you on that Impound Yard deal, or how that relates to the flat tire.
When I get a flat I put the spare on and drive it to a Tire Shop.. :confused:
