Rough running 94 olds88
DB208508
05-06-2007, 09:32 PM
My buddys 94 88 idles rough and it accels like crap, unless you ease into the pedal, checked the plugs and wires they look new, only have little over 20k on them
3800 v6 154k miles
maxwedge
05-06-2007, 10:27 PM
Welcome to AF. Pretty general question, does it have a dead miss? You need to pinpoint the symptoms a little better, the list is long for that description.
guitarsandcars88
05-06-2007, 10:53 PM
Wellllll...I'm not sure, but start with the MAF and EGR. I've known a few 94 88s where the EGR just stops working and it will run like total crap. Just take the EGR off and plus the hole where the exhaust gas go into the throttle body. If it runs better, that MIGHT be it, if not...then I dont know. Start with the obvious though.
DB208508
05-07-2007, 02:24 PM
The symtoms are it has a rough idle, and it idles at about 1100rpms, when you hit the gas it sounds like there is a miss on one of the cylinders, but when you push the gas pedal down slow it sounds fine, checked the MAF screen and cleaned it already, will check the EGR.
EDIT:
Checked EGR working fine, checked the fuel filter, checked coal packs too and there working, checked wires and working, checked MAF again and it's working, checked all fuses and relays, there all working.
razr_88
05-08-2007, 11:22 AM
get it checked for code before you start throwing parts at it. you can get them checked at autozone. a code could assist you immensly
DB208508
05-08-2007, 02:33 PM
but would it be throwing code without the check engine light on besides the usual KR stuff?
razr_88
05-14-2007, 09:14 AM
yes sometimes the codes do not set off the ses light.
