2001 TDi code P1650
woolfmaster2005
04-28-2007, 07:40 PM
Hello.
My 2001 Beetle 1.8 TDi would fire up and stall. after 4 tries it ran.
set a code P1650 Data Bus Powertrain Missing message fr.instrument panel ECU. where do i start looking?
i drove it and it ran fine. tryed to start again the samething. cleared code and started it up three times started two times ok then number three stalled and set same code...
any help will be great!
veedubmechanic
04-29-2007, 04:57 PM
You need a new instrument cluster. The immobilizer portion of it has failed.
woolfmaster2005
04-29-2007, 06:16 PM
Question? is this something that will put me on the side of the road? i tryed starting it like 5 times ran fine...the code came back each time i cleared it and restarted it...Is this a DIY?? i am a ASE master.. not on VW....GM,Ford,Jeep.
Any guess on the cost?
Thank you for an answer to what was wrong! This is a great Forum!
Tom
woolfmaster2005
04-29-2007, 06:45 PM
I have been looking on the net...Funny thing This all started after i Dropped(hit hard) my keys in the parking lot. Did i damage the remote ??? I see something about a chip in it? just asking...also never had a battery in the remote??.....
Thank you....
hako
04-30-2007, 02:56 AM
First I'd fit a new battery to the remote, if it doesn't work get the remote reprogrammed to the car. A damaged remote can still open the doors but fail to get past the immobiliser. A new instrument cluster will cost an arm and aleg so That would have to be a last resort I'd reckon. I think VW have to reprogram the remote....you don't have a spare?
Good Luck.
woolfmaster2005
05-01-2007, 06:40 PM
I have been driving the car now for 2 days..No problems...????I have not reset the light. when i dropped the keys it was sticking out...Thanks for all the help so far...
Tom
hako
05-01-2007, 10:49 PM
Tom
While lucks on your side it might be a good idea to get a second key head and remote programmed because it "probably" will happen again and it might be at 3AM in the backblocks! They are on Ebay I've heard but think only VW can then program them. Good Luck.
veedubmechanic
05-05-2007, 10:03 PM
You need the key programmed since its a 2001 at the dealer. It will cost about 160.00 for the key at the dealer and 50-100 to program it.
