Vs commodore issues
inoutinout
04-26-2007, 12:23 AM
I recentlybought a wagon.
The other day i was driving it and it stalled i was doing roughly 60kmh and would not start again.
After towing it home i tried charging the battery, It wouldnt start. Tried a new alternator would not start.
I am completely stumped Tried the strter moter but that wouldnt have aused it to stall in the first place.
any ideas much appreciated
Morgz
08-20-2007, 05:05 AM
Try your ignition module or coil. Had same prob about a year ago on my VS SS, this fixed it. Cheers and good luck
mmcleo11
08-22-2007, 04:59 AM
Check the harmonic balancer which is the bottom pulley of the belt at the front of the motor. If the rubber is damaged, it stops the engine from picking upa a signal from the crank angle sensor. The crank angle sensor tells the computer when to fire the ignition coils and inject fuel so the ECU will not allow the car to 'start'
