rca question.
PlayStation3
04-25-2007, 03:17 PM
hi, the dvd player that i want to use is pioneer AVH-P7600DVD now it has 6 pre amp rca's. FR, FL, RR, RL, C, Sub now i have a 4 channel amp that has 2 inputs now how would i do the rca's.
bjboertje
04-25-2007, 06:20 PM
what 4 channel amp only has 2 inputs?
RF and RR into right, LF and LR into left, leave C and sub out of that amp. you won't get the true surround sound that way though.
PaulD
04-25-2007, 08:44 PM
4 channel amps have 4 inputs .... otherwise it's pointless
PlayStation3
04-25-2007, 10:30 PM
i mean 2 sets. that dvd has 6 sets. a set for each speaker.if i got some of these http://www.monstercable.com/mpc/productPageMPC.asp?pin=3251§ion=four&LastPage=400%20Interconnects
would that be able to work. like make the left front right and left join together and then do the same thing to the other side.
PaulD
04-26-2007, 08:40 PM
DO NOT do what I think you are trying to do. Instead, put the FL, FR, RL, RR into the 4 channel amp, then get another amp for the subs
PlayStation3
04-26-2007, 09:00 PM
hold on what i get when i see that this is what i get. there is set of rca for the fr, a set for the rr, a set for the fl, a set for the rl, a set for the center and a set for the the subs. and by set a mean a red and white, you know left and right.
bjboertje
04-29-2007, 10:26 AM
then just like normal, but use a separate amp for the sub, and center if you watch a lot of movies in your car.
PaulD
04-29-2007, 11:15 AM
I would have to see it, but it sounds like you are describing a differential output from the DVD player ..... that's a whole different can of worms you are opening.
PlayStation3
04-29-2007, 11:56 AM
nevermind i just got my email from pioneering so that i can login in to read their installion manuel and they counted each left as a set and a right as a set. so nevermind i guess
PaulD
04-29-2007, 04:03 PM
I am still a bit confused .... but if you wanna email the .pdf to me it might make more sense
pimprolla112
04-29-2007, 11:33 PM
From the sounds of it im getting one set of preamps for each speaker. I could under stand front/rear/sub/center. So 4 but why seperate each speaker into its own set of outputs.
Mine has 3 outs and aux in, satellite/cd changer.
heres the cardomain page for it. My net blows so i was getting lazy for it to load.
http://www.cardomain.com/item/PIOAVHP7600DVD
PaulD
04-30-2007, 09:29 AM
yea, I see that now ...... it's just a standard 5.1 output scheme
pimprolla112
04-30-2007, 09:41 AM
Well that makes more sense then.
PlayStation3
04-30-2007, 02:33 PM
this should be a good head unit to use for a system right cause i made sure to look for one with atleast 4volt pre amp.
PaulD
04-30-2007, 04:53 PM
you should be good to go .... but me thinks you are gonna have a lot of tuning and adjusting to do on this system
PlayStation3
04-30-2007, 05:42 PM
that part is cool with me cause i am a tuning freak i mess with the eq like every other song.
pimprolla112
04-30-2007, 11:49 PM
All i have to say is goodluck on the tuning. Ive got 5v biatch now what. JK man. 4 is better than alot of units out there.
PlayStation3
05-01-2007, 06:15 AM
that one is 5 volts. i just wanted to make to sure TO get one with atleast 4v
