Wierd Sound from 2000 Crown Vic
bud4u
04-21-2007, 10:26 PM
I have a wierd moaning sound coming from the air filter housing
on cold startups, it usually lasts for under a minute. Could
the MAF sensor be causing this problem ??? If not, does anyone
have any thoughts or suggestions as what would cause this loud,
wierd moaning sound ?
I only have 49000 mi on it & I bought it new
Any help will be appreciated.
Bud
way2old
04-22-2007, 05:43 PM
It is either the idle speed control motor or the lottle plactic tube that runs from the iac to the throttle body intake hose
1996Chreokee
04-24-2007, 03:23 PM
maybe a power steering pump? and the noise is radiating toward the air box...?
exit26
05-01-2007, 08:57 PM
Bud
Underneath the air box is the air compressor (assuming you have rear air bags?) the pump is on leveling the car on start up. The pump may be going bad.
