popped turbo return oil line
boosted95clipse
04-20-2007, 06:07 AM
so ill go into a little more detail. i was about a 1/4 from my house and i noticed the oil pressure guage slowly going down so i slowly limped it back to my house and go it there and it was still running ok. i shut it off, popped the hood and saw that i must not have secured the oil return line from my precision 50 trim turbo and so i put it on and let it sit for a little while. then i put oil in the car and tried to start it, and it would turn over but wouldnt start up for me. does anyone know what could have happened? if so i would appreciate some help
boosted95clipse
04-20-2007, 05:19 PM
im new to this site but will someone please help me?
NOFX0617
04-23-2007, 10:33 PM
How long ago did you install the turbo? After the installation did everything start up just right?
Also if you could put your mod list in your signature that would help out as well.
Just as a note sometimes on the weekends you wont get a lot of responses from people on here because a lot of people go out and dont spend much time on here. At least that is what I have noticed.
boosted95clipse
04-24-2007, 01:54 AM
yah it started up fine and drove fine till the oil return line came off
NOFX0617
04-24-2007, 10:24 PM
Were you judging your oil pressure by the stock gauge?
Have you done any tests like a compression test, spark test, fuel test. To make sure you are getting everything you need to start up?
boosted95clipse
04-25-2007, 11:44 AM
wasnt on stock guage, and the compression, and fuel are good.. probly need to pull the plugs...
