Power wire question
max_max
04-18-2007, 10:08 PM
ok im trying to hook up and amp in my truck but i dont want to run a dang power power wire all around my engine comparment is there any way i can tie into the fuse box?
PlayStation3
04-18-2007, 10:52 PM
i doubt it will fit.
Newbster
04-19-2007, 08:19 AM
Put it along the side with your battery on it. Use split loom. Im sure theres a way you can weave it in there unnoticably.
sr20de4evr
04-19-2007, 08:24 AM
No, the wiring and fuses are too small to support an external amp
In the time it took you to sign up on this forum and make this post, you could have had the wiring in your engine compartment done...it only takes a few minutes to an hour tops.
PaulD
04-19-2007, 06:34 PM
^^^ what he said
what size amp(s) are you trying to power ?
