MAP Sensor
Genopsyde
04-15-2007, 09:56 PM
Ok, saturday I start the car up for the first time in about 2 weeks. It idles really rough and is rough when i rev it up a bit. SES light then comes on, code 33 MAP sensor voltage too high. I check the voltage for the MAP sensor according to the instructions in the manual (ignition on/engine off) and it reads within acceptable parimeters. We checked for vaccum leaks and found none. The car ran perfectly fine 2 weeks ago, I changed nothing. Any advice on where to go from here?
1991 RS BTW
1991 RS BTW
Genopsyde
04-16-2007, 09:34 PM
wow, no support at all.
Morley
04-17-2007, 01:30 AM
It only takes a very small vacuum leak in the hose going to the MAP sensor to throw it off. I would start by replacing the vacuum lines associated with the sensor. After that...new sensor. They cost about $35-$40.
Genopsyde
04-17-2007, 03:35 PM
Morley, I appreciate your resonse, thank you.
Morley
04-18-2007, 01:24 AM
NP. Try this site for further MAP troubleshooting http://www.automedia.com/Sensor/Troubleshooting/Manifold/Absolute/Pressure/ccr20011001mp/1
Also, the EGR and its vacuum lines can affect the MAP sensor.
Genopsyde
04-18-2007, 04:43 AM
thx again. I got a few good suggestions on TGO too. I removed egr and had it programmed out as well tho.
