Unlock Door With Key - Anti-theft Alarm Sounds
Doh62
04-13-2007, 04:07 PM
Hello All, I have a 97' Villager and do not use the keyless entry fobs to unlock or lock the doors; I have not used the fobs since their batteries ran out. No problems with unlocking and locking the doors with the keys only; that is until now.
Problem: I use to key to unlock driver door and the anti-theft alarm goes on. Will not stop even when I place key into ACC position.
Any help would be appreciated. Thank you.
IH8SPM
04-15-2007, 08:43 AM
Start using the key fob. The problem is that you proably have a bad connection at the drivors door switch and its causing the alarm to engage when you lock the doors and not disangage when opening. Wait do you have a factory or after market alarm?
Doh62
04-16-2007, 01:50 AM
Hello IH8SPM,
Thank you for your response.
I have ordered replacement batteries for my current fobs. Also, I have ordered new fobs; I ordered them from e-bay.
Until both arrive, I have found that I can deacticate the alarm by placing the key into the back hatch and turning the key towards the left (lock) direction.
I will update this post when the key fobs and batteries arrive. I found programming instrutions on the net.
Thanks again.
Thanks again.
