05 caravan 3.3 p0016 code
drssales
04-11-2007, 12:44 PM
An 05 caravan with the 3.3 with 120k on it will throw the sevice engine light than shudder and not run correctly. Have replaced both the cam sensor and the crankshaft sensor but has not solved the problem. Any other ideas would be greatly appreciated.
jsinton
04-11-2007, 04:25 PM
Your code "p0016" does not make sense. It's not an ODB II code. Did you get it from turning the key on "on-off-on-off-on"? If so, the trouble code means you have "battery voltage sense input not detected during engine running."
gromittoo
04-12-2007, 11:41 AM
My Actron scanner came with lookup software. I entered the DTC of P0016, and I get:
Cam/Crankshaft Pos. Correlation Sensor A - Bank 1
RIP
04-12-2007, 12:57 PM
It's not likely but, possible. Your timing chain may have jumped a tooth and thrown the timing off. The sensors may be sensing an out of timing condition as they are designed to do. Can you expand on "not run correctly"?
P0016 is a generic "non Chrysler specific" code.
drssales
04-12-2007, 03:37 PM
thanks for the responses....the vehicle was transferred to another division of the company and it is no longer under our care. So I can not even tell you when it gets fixed what the cause was. But I appreciate all of your time.
