p0137
alfieferenzo84
04-10-2007, 08:35 PM
anyone know what it is and what to do about it? Thanks
richtazz
04-11-2007, 05:40 AM
p0137- low voltage signal oxygen sensor-bank 1, sensor 2. Since our cars only have 2 sensors (there is no bank 2), this indicates a problem with the post-converter oxygen sensor. Usually low voltage codes indicate a bad/dirty sensor and replacement will cure the issue. You may still want to inspect the wiring to it also, just in case.
