gauges
Phat8186
10-12-2002, 07:42 PM
i just installed reverse indiglo gauges on my 96 accord ex.The only thing I am not that sure of is where should I tap into for a sufficent power source. Can someone please help me.
tenguzero
10-14-2002, 11:04 AM
I just took a T- tap (little plastic crimp on that lets you splice a wire into an existing line) and tapped right into the power wires that run into the factory dimmer switch. You can tap either the red or the red/black wire. One is the constant power source, the other is the dimmer controlled power source. It varies between Honda's as to which wire to tap. I think I tapped the red one, which I found out is the dimmer control. The gauges still work fine though, they just adjust opposite of my dashboard lights when I use my factory dimmer (dash lights get brighter, gauges get dimmer) but I just brighten them up again using their dimmer. One thing to note, I don't know about the '96's, since Honda did a little tweaking on those, but my model doesn't have light up needles, so they barely show up against my gauges at night, but I've gotten used to it.
BluJ
12-25-2002, 06:26 PM
WATS UP GUYS, I WANT TO BUY THE AC AUTOTECHNIC REVERSE GAUGES, AND I HEARD A LOT OF THINGS ABOUT REPLACING THOSE GAUGES. THE NEEDLE IS SENSITIVE AND YOU MIGHT MESS UP THE WHOLE CALIBRATOR, AND THE THING I AM SOOOOOOOO WORRIED THE MOST IS THAT IF MY NEEDLE MESSES UP, MY WHOLE WARRANTY IS VOIDED. WHERE IN NEW YORK CITY IS A SUPER PROFESSIONAL WHO CAN PUT THE GAUGES AND THE NEW NEEDLES I JUST SAW, SAFE AND SOUND? PLEASE GUYS HELP ME OUT ON THIS ONE. THANKS A LOT
