How to remove....
Anonymous User
04-04-2007, 10:59 PM
Does any one know how to remove the panel that is on the rear tailgate? I need to know how to, because I got a dent that I want to push out. Also how do I remove the front door panels also.
Thanks
cjstew4
04-05-2007, 12:22 PM
Let us know since I have a dent below the rear wiper in mine that I want to push out as well. I talked to a dent repair guy and he said that for mine to put a towel in the palm of my hand an pop out as much as I can before you call in the dent repair folks to save money. He said that a lot of times just the palm of your hand and towel can get it back to almost pre-dent state.
cdru
04-06-2007, 09:59 AM
ThanksI believe both of them are held into place by little plastic "tree" barbs. They are a real PITA sometimes to let loose and plan on replacing some of them that get significantly mangled.
Anonymous User
04-09-2007, 08:19 PM
does any one know what type of bolt/screws that are the ones that hold on the rear hatch panel, there near the handle.
HC2000
04-13-2007, 09:45 PM
Hi,
I believe you are describing the "torx" screw head design. This is one of the replacements over the years for the ole straight and phillips head design. You know, this encourages us to do one of two things; Take it back to the dealership for the repair, or keep buying the newer tools!:disappoin
Regards,HC2000:)
