Daytime Running Lights
FireEmtDave
03-29-2007, 04:44 PM
99 safari, my drl's do not work. Dash indicator light does not come on. High beams are good. I've check the fuse. Where would the relay be? Anything else I should check? Thanks!!
boatbuster
03-29-2007, 07:57 PM
I don't know if yours is the same as mine. I have a 2002 AWD and the daytime running lights only come on when I have the van in drive. Have you checked if they come on in drive?
Just a thought! Let me know if yours does the same thing!
FireEmtDave
04-02-2007, 09:16 PM
Didn't make a difference. I know there has to be a relay somewhere. Just don't know which one.
drew300
04-03-2007, 11:43 AM
my '97 has a switch connected to the emergency brake pedal, for the DRLs.
ASTRODRAGULA
04-05-2007, 11:38 PM
I dont have any help for the fireman on this one, but since the subject is open. I have a 97, the day lights havent worked since i got it but the green light in the dash is always on ? Any suggestions? I'll check out that switch
ASTRODRAGULA
04-05-2007, 11:44 PM
I just read the rules.......Kind of late , and I do apologize for asking a question in Daves question>>> that even sounds confusing , I will be more careful in future:banghead: :icon16: :frown:
Vinnie6
06-08-2008, 09:10 PM
I know where the relay is. At least on the 2002. The dealer did the work, so I cannot get specific, but it is in side pillar behind the driver's seat. You must remove the front bench seat and pop off the cover by where the rear heat comes out. That's all I know.
harryevan
06-10-2008, 11:56 PM
Once I switched out the dealer upgraded radio/cassette/CD player, I could push the dome override switch twice and control the rnning ights and the daytime DLRs. I read something about the illumination wires being used for a radio, didn't think the dealer would mess it up...
diggin
06-14-2008, 05:06 PM
I had the same problem and it was the drl diode which is right beside the drivers seat behind the door post , costs about a hundred bucks. Looks like a small box with alot of cooling fins on it , you can test by jumping the connector but don't leave it that way as it illuminates the high beams. After mine was fixed the small light on the dash never worked afterwards.
