Oil fouling estimate
Prime First
03-24-2007, 03:23 PM
Hey guys. I have a 420A with tons of oil getting into cylinder 1, causing a misfire reading. I'm guessing I have bad piston rings or valve guides?
Could you guys give me your idea of what a fair price would be to work on this? I am planning on finding a shop pretty soon. But I don't know what prices to expect.
Thanks!
Scrapper
03-24-2007, 03:56 PM
yep rings..i'm in ndiana if your around here?? got 1 heck of MC. the other 1 past way it was pudge we call him he worked on them night and day they can rebuild 1 on the road...anyhow around here now i think rowe trucking best other place...like i said if your in indiana....good luck....
scrapper.....
david-b
03-24-2007, 07:14 PM
Could be a head gasket, rings, valves, valve guides, valve seals... there's more than just one cause of that.
A shop will charge you up the ass for work like that. If it's head work, you're not looking at too huge of a price. Maybe around the $400 mark, maybe even more. If it's rings, you've got a little more money there. Be looking at at least $600 I'm guessing. Either way, the head has to be ripped off, timing belt removed and retimed, and more. It's time consuming and a rough job. It's not easy at all.
Go around to your local shops and get pricing. Cheapest is not always the best route to go. Find places that are reputable and willing to get their hands dirty. Any place you go, go in there acting like you know exactly what you're talking about. Tell them, "I have this problem, either caused by this or this. What do you think and how much?" Then there's less of a chance of getting raped with labor and parts. Good luck and let us know how much they think.
Prime First
05-20-2007, 01:35 PM
Alright guys, I have an update after what seems like an eternity.
I had the valve cover seal replaced for about $180 over here. But the misfire continued right after I left the shop. I didn't complain that much since I figured I needed to take care of that oil leak anyways.
But I called the shop back and the dude figured it was the coil pack. He wanted to charge be $200 to replace it. Advance had a coil pack on sale for $78 so I did it myself. But that still wasn't it!!
Any ideas where I should look next? I'm not sure how to mess with wiring or whatnot.
Thanks in advance.
l_eclipse_l
05-20-2007, 09:16 PM
Did you replace the plugs after you had the valve cover gasket replaced? Did it actually fix the oil leak?
Scrapper
05-21-2007, 01:35 PM
could be tps,cps or your module under the coil pack..good luck...
scrapper....
l_eclipse_l
05-21-2007, 09:17 PM
What are you talking about? I don't remember seeing anything under the coil pack when I upgraded mine.
Scrapper
05-22-2007, 06:49 AM
square box under coil pack it is the same size as coil pack..and coil pack screws down on coil pack..
Prime First
05-23-2007, 01:19 PM
Sorry, I don't follow? What engine are you talking about?
I didn't replace the plugs or wires, because they both looked pretty good. The plugs fire correctly, but the firing is just inconsistent...so I'm thinking it's something else? Idk. Thanks for the help guys. Let me know what you think.
