engine screeching
Brfuga32
03-24-2007, 01:06 PM
Whenever my engine reves, there is a loud and annoying screeching sound that comes from the engine. I believe it is either the idler pulley or the alternator; somewhere around there. It is especially evident when it is wet outside or when it rains. Otherwise it doesn't really make much noise. I tried putting some dishsoap (like a friend told me to do) on the belt and that works for a little bit but it comes back. Any help?
old_master
03-24-2007, 06:22 PM
If the soap helps, it's probably the belt. When you have the belt off, check the idler pulley and belt tensioner. They should both rotate smoothly and quietly with no wobble.
