98 Malibu
darlea
03-19-2007, 05:17 PM
I have a 98 Mailbu with about 150,000 miles. It run good but once in a while it just loses power. By that, I mean the dash lights all come on and the car actually dies for maybe 4 or 5 seconds and than the dash lights go off and it runs fine again. Any clues?
HyperFox
03-19-2007, 07:01 PM
Could be a bad ground. Perhaps a dying regulator, weak battery.
Negatoro
03-21-2007, 12:03 AM
Please be more specific.
Dash lights?
Car dies = Motor shuts off?
-Mark T.
Dash lights?
-Mark T.
darlea
03-21-2007, 02:47 PM
ok. i noticed when i first start the car the theft system light stays on. if i drive off with that light on, the car eventally dies but restarts again. if the the theft light system light comes on when i start the car and i turn it off and restart the car and the light doesn't come on, the car doesn't die. every once in a while the battery light will stay on once the car is running. but if i turn the car off and restart, the battery light goes off....any clues or suggestions?
Negatoro
03-21-2007, 09:33 PM
Inspect all Charging system connections and clean/replace if necessary.
Batt+ terminal
Batt+ cables and connections [underhood junction box/starter]
Starter+ cable to Alt+ and Alt stud.
Batt ground terminal
Batt to engine/chassis ground cables and connections.
My guess is bad ground. That could easily cause intermittant Batt light.
Then write back.
-Mark T.
Batt+ terminal
Then write back.
-Mark T.
