locked in 4wd help
pinhead989
03-15-2007, 01:40 PM
when you start the truck the thing in the passenger kick panel clicks constantly for about 1min then stops and says 4lo on the switch. i click the 4hi or 2hi and it will blink then when i put it in nutral it clicks back to 4lo. ive tryed to disconnect the vac lines and its still locked in i disconnected a sensor on the front axel ..nothing, i throw it in reverse and hit 4hi it flashed until i hit nutral at 2mph. i personaly think its a encoder motor but id rather find a way to manual put it in 2hi and not us 4wd since summer is almost here..someone said if u take a pair of pliers and turn something on the tranfer case it will go into 2hi? idk anyhelp would be apprecialted
brian
MT-2500
03-16-2007, 09:41 AM
brian
We need the year make and model and engine.
And also what transfer case you have.
There is a ID tag on back of transfer case.
MT
pinhead989
03-18-2007, 12:11 AM
sry its a 99 blazer ls 4x4 with 3 button and auto tranny ill get back to u tommrow on the tag number
MT-2500
03-18-2007, 09:48 AM
3 button may be a 233.
As always check fuses and wiring and plug ins.
If a 233 you can pull codes by grounding pin 13 on the diagnostic connector.
And always run a search in the how to sections.
Here is on link from thee that may help.
http://www.automotiveforums.com/vbulletin/showthread.php?t=572914
Let us know how it goes.
MT
robertpreuss
03-19-2007, 09:28 PM
hi i own a 95 and 96 blazer.......the 96 just recently gave me problems with locked in 4wd also........turned out to be vacuum switch located on transfercase on top at drivers side 3 vacuum lines on switch holding front diff locked check this out.......i removed vacuum line from front actuator under battery for tempoary repair till i got new switch.........quote=pinhead989]sry its a 99 blazer ls 4x4 with 3 button and auto tranny ill get back to u tommrow on the tag number[/quote]
