T-bird wheel bearing
Jwieg
03-15-2007, 12:41 PM
What is involved in replaceing the front wheel bearing on a 95 TBird?
What size socket do I need to remove the bearing assembly?
What is it torqued to?
overl0rd
03-15-2007, 11:08 PM
Remove wheel, caliper/brake parts, rotor, unbolt hub, pull with slide hammer or air hammer or BFH, whatevers available. Installation is the reverse of removal, torque caliper anchor bolts to 95 ft.lbs, all others to 40 ft.lbs.
SwiftThunder
03-16-2007, 12:49 AM
I replaced my front bearings on my 97 and it was pretty simple, The hardest part was finding the right socket, I believe it was either a 32mm or a 36mm 6 point DON'T use a 12 point socket cause it won't fit. If I remember for sure what size specifically ill repost it.:grinno:
