Ranger Transmission
cousinles
03-14-2007, 06:23 PM
I got a 93 ford ranger 3.0L 4x4 given to me and the transmission is bad. The guy who gave me the truck said it has a very rare transmission and they only made them for that year and no salvage in my area yards have any he found a referbished one for $1200 . I did some resarch on the internet and found it has a L4D1 transmission and they are very common in rangers, bronco and explorers. Is my info I came up with true or is he right? any help will be great.
corning_d3
03-14-2007, 07:09 PM
I'm assuming it's an automatic?
cousinles
03-14-2007, 09:30 PM
yes it is
corning_d3
03-14-2007, 10:00 PM
This is what I come up with:
There are 5 automatic transmissions used in the Ford Ranger, Explorer and Mountaineer. They may be identified by checking the transmission code on the Safety Standard Certification Label attached to the driver's side door post, in the space marked Trans. The transmissions can also be identified by a tag attached to the lower left hand extension attaching bolt. The transmission codes are as follows:
1991-94 code T is for the A4LD transmission
1995-99 code T is for the 4R44E (2.3L, 2.5L & 3.0L) or 4R55E (4.0L) transmission
1996-99 code U is for the 4R70W (5.0L) transmission
1997-99 code D is for the 5R55E (5-speed automatic) transmission
All of the automatic transmissions are 4-speed units with a lock-up torque converter, except the 1997-99 5R55E, which is a 5-speed unit with a lock-up torque converter.
e_powers
03-15-2007, 04:11 AM
when you look for the transmission you also need to consider the engine it was once connected to. the bell housings between the 3.0 and 4.0 are very different.
cousinles
03-15-2007, 03:09 PM
Thanks a lot you guys were a big help.
