Oil pan/drain plug problem
jaharbert
03-13-2007, 09:28 AM
Has anyone received a similar service report:
"Customer states oil drain plug stripped out. Oil pan stripped and drain plug had heli coil on it. Advised customer that proper repair was to replace oil pan $1205.95 plus tax."
Any suggestions?
Thanks,
Joe
rodeo02
03-13-2007, 12:19 PM
A very common occurance when you don't do your own oil changes. Is the helicoil posing a problem?, if so, your only options are to: Install a fumoto or fram sure drain, drain valve and hope it doesn't leak at the pan. Or replace the pan with a new or used one.
Joel
jaharbert
03-13-2007, 01:29 PM
Thanks, Joel.
The problem is the Dealer, where I bought the car in June, in addition to advocating a new pan, is all-but-saying that my private mechanic stripped the thread during an oil change. I don't believe that he did.
rodeo02
03-13-2007, 06:09 PM
I bet that pan drain was partially stripped out before you bought the truck. If it were mine, I'd leave the helicoil and thread in a fumoto drain valve. That way you wont have to disturb the treads, only open/close the valve to do an oil change. Fumoto's use a nice big thick nylon type washer.
Joel
