Vauxhall Astra Estate 1.7 Dti
robertcodfather
03-10-2007, 02:45 PM
I Have a 2001 vauxhall Astra 1.7 Dti ,
Lately i have noticed that when i turn the engine off, i hear 4 beeps coming from the Passenger side at the front of the car under the bonnet,
This does Not happen every time i turn of the ignition:banghead:
Any Clue,s very much Appreciated
sidv6
03-28-2007, 02:46 PM
hi robert the noise u r hearing is the alarm siren its located behind the passengers wheel splashguard the fault is the internal battery of the siren going flat sometimes caused by water ingress if u have to replace it be sure to have the ignition turned on before disconnecting siren or it will go off constantly
good luck sid.
good luck sid.
Jhonny j
01-21-2009, 01:57 PM
my cousin has an astra 1.7dti and he had a lot of problems with this car.now it wont starts in the cold morning.
robertcodfather
12-08-2009, 09:26 AM
Thanks Sid Problem now fixed Thanks to you
Followed your advise now problem solved
Many Thanks
Rob
Many Thanks
Rob
