94 Tbird 3.8 almost stalls at red lights
reino134
03-08-2007, 10:53 PM
after the car warms up when you stop at stop signs or red lights the car will act like it is missing cylinders, will not shut off just idle terribly! I have already tried replacing the IAC, Distributorless Coil Pack, Plugs, Wires, Cleaning the MAF, Replaced the O2 sensors. Any ideas or help would be greatly appreciated
overl0rd
03-11-2007, 04:50 AM
Vacuum leak? If you rule that out then for shits and giggles run a compression check on all the cylinders. They should all be pretty close to the same (about 10% variation is the upper limit of acceptable).
reino134
03-11-2007, 07:35 AM
thanks for the input, it was in fact a vacuum leak the small pipe from the pcv came loose under the intake. Not a fun item to get back in place! But it cured the problem
Thanks agiain for the response
