Dash lights 95 tbird
Rogerdoger46
03-06-2007, 09:40 AM
Hi I need some help on my 95 tbird the dash lights are out but only for speedo tach ect... the signal and chk eng lights work fine how can I fix this?
KimMG
03-06-2007, 04:58 PM
Are you refering to all the dash lights that come on with the headlights? Or just a couple of them?
97Bird
03-06-2007, 05:37 PM
Welcome to the forum Rd. Be sure the dimmer switch wasn't turned by mistake and check the fuse in the fuse block under the dash. It should be a 5 amp fuse and probably says CLUSTER above it. It's to cold for me to go out and check for sure.
Rogerdoger46
03-06-2007, 10:13 PM
All for the head lights in the dash check fuse box try the dimmer switch.
97Bird
03-08-2007, 01:30 PM
Don't know what you mean. Did you check the fuse and dimmer switch? If the fuse is good and the dimmer switch is in the correct position then you will need a 12V test light or voltmeter to start tracing the circuit from the fuse up to the dash panel. Did the lights stop working for no apparent reason or was someone doing something like installing a radio or something else behind the dash before they quit working?
Rogerdoger46
03-12-2007, 10:00 PM
Well I check the fuse it is find so I remove the dash to see if anythng was lose unplug then I put it back togethier and it works thanks for the help 97tbird
97Bird
03-18-2007, 10:41 AM
You're welcome. Glad you got it fixed.
