99 GP GT Serpentine Belt Replacement
wiz33064
03-03-2007, 06:14 PM
Have a 99 GP GT with 3.8 no Super Charge Was doing some PM's on it and notice some cracks in the Serpentine Drive Belt. How many miles do you get out of one and are they a bear to change. It don't look to bad but you never know what's going to happen when you get in to it. Thanks in advance....wiz
guitarfish
03-03-2007, 07:07 PM
I generally get about 60-80K miles for a belt, I'm due to replace mine now. I will be getting a Gatorback (http://www.goodyearbeltsandhose.com/cars/gatopoly.html) belt, this will be my first one. They're supposed to be quieter, better.
ericn1300
03-03-2007, 11:01 PM
I swap mine out at about 75K or as soon as i notice any wear or cracking, and i put the old one in with the spare tire for an emegency spare.
jeepgclwj
03-04-2007, 12:23 AM
I just did the same thing. Never know if you might need it...
abesafab
04-09-2007, 01:12 AM
You need a 15mm socket to fit on to the idler pully to take the tension off the belt so you can get the old one off and install the new one. It's fairly easy to do.
richtazz
04-09-2007, 06:37 AM
Changing the serp belt takes less than 5 minutes. Open the hood, release the belt tensioner, and slip the belt off noting it's routing. Re-route the new belt around the pulleys, and you're done. There are no motor mounts/brackets/pieces in the way like some cars have.
