99 with Crazy Electrical Problems
IndianaAbsentee
02-26-2007, 07:01 PM
My wife's 300M is posessed. :evillol: The headlights turn themselves on and off whenever they want to, even if the car is turned off, no one is in it, there are no keys in it, and it's sitting in the driveway by itself.
Also, sometimes the dome lights just come on and off while we're driving down the road. No rhyme or reason to that either.
We've got a new problem this week. The dashboard trouble indicator lights are on. ALL OF THEM are on. They have been on for two days, and there's nothing wrong with how the car operates.
I've tried disconnecting the battery for awhile to see it that works. The lights went off. We started the car, they all came back on again.
Any ideas? Anyone have similar problems?
tinmanwpk
02-27-2007, 10:49 AM
Present your problem at 300mclub.org. I am not saying we can answer it, but collectively we can come up with some good leads to follow. You have a unique problem I am not familiar with, and that is why we have our club. It is the most definitive 300M group anywhere. Please check us out!
tinman
hundahunta
03-02-2007, 02:26 AM
NO: 08-53-98
SUBJECT: Courtesy Lamps Flicker
DATE: Dec. 11, 1998
THIS REPAIR IS COMPATIBLE WITH DIAMLERCHRYSLER'S MOBILE SERVICE PROGRAM AND DOES NOT REQUIRE HOISTS OR OTHER FULL SERVICE FACILITY SPECIAL EQUIPMENT.
NOTE: THIS BULLETIN APPLIES TO VEHICLES BUILT BETWEEN JULY 20, 1998 (MDH 0720XX) AND OCTOBER 23, 1998 (MDH 1023XX).
SYMPTOM/CONDITION:
Some vehicles may have the roof (headliner) mounted courtesy lamps intermittently flicker when they would normally be "ON" (door open/switch on).
DIAGNOSIS:
Remove the fuse panel cover from the left end of the instrument panel. Install the M-1 (IOD) fuse if not already installed. Move the pink wire (M-1 circuit) coming out of the white C-11 connector located in the upper front corner of the fuse panel back and forth. If the roof mounted courtesy lamps flicker "ON" and "OFF" as the wire is moved, perform the Repair Procedure.
PARTS REQUIRED:
Qty Part No. Description
1 56019990 Terminal
REPAIR PROCEDURE:
This bulletin involves testing and if necessary replacing M-1 terminal in the C-11 connector.
Disconnect and isolate the negative battery cable remote terminal.
Press the tab and remove the C-11 connector from the fuse panel.
Lift the locking wedge tab (moves up 2 mm).
Remove the pink M-1 circuit from the connector using Miller Special Tool 6680-2.
Cut off the existing terminal at the base of the terminal.
Strip off the insulation from the wire to expose 1/8 in. of copper wire. Make sure the strands of wire are not cut, just the insulation.
Carefully crimp new terminal, p/n 56019990, into the wire using crimping tool, Snap-On p/n PWC46, or equivalent.
Install the M-1 pink wire/terminal into the connector; reset the locking wedge.
Install the C-11 connector and verify courtesy lamp operation.
NO: 08-09-99 Rev. A
SUBJECT: Interior Lights Will Not Illuminate **Or Lights Staying On**
DATE: April 16, 1999
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-09-99, DATED MARCH 26, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE AN ADDITIONAL SYMPTOM.
OVERVIEW:
This bulletin involves locating and repairing cut/grounded wires.
SYMPTOM/CONDITION:
The interior lights will not illuminate and the fuse is blown **or the interior lights stay on**.
DIAGNOSIS:
Remove the eight (8) way connector on the headliner wire harness from the connector in the outboard drivers side of the junction block. If a new fuse does not blow, perform the Repair Procedure. If a new fuse still blows, continue normal diagnostic procedures.
REPAIR PROCEDURE:
THIS REPAIR IS COMPATIBLE WITH DAIMLERCHRYSLER'S MOBILE SERVICE PROGRAM AND DOES NOT REQUIRE HOISTS OR OTHER FULL SERVICE FACILITY SPECIAL EQUIPMENT.
Examine the headliner wiring location near both rear grab handles for cuts, rub through and witness marks. Repair as necessary.
Connect the eight (8) way connector to see if the fuse will blow.
If the fuse blows, remove the C-pillar and package shelf trim. Examine the wiring location near the trunk lamp for cuts, rub through and witness marks. Repair as necessary.
If the fuse still blows continue normal diagnostics of the headliner wiring harness.
POLICY: Information Only
I found these tsb's does not sound like these apply but FYI.
I would also check the multifunction switch.
Or it could be a problem with the bcm, possible you need to scan for any dtc's
tinmanwpk
03-05-2007, 07:01 AM
Many M's have had faulty connections with their headlight switches as well. This may be part of the problem, too. There are detailed repair procedures at another website.
95 LeSabre
09-14-2008, 09:00 AM
I know this is a old thread but has anyone found a fix for this? My father-in-law's Concorde is doing the same thing?
