No Spark and Fuel E150
jc0021
02-24-2007, 11:46 AM
OK,
This problem started w/ fuel pump not working...
I hot wired it via the pump shut off relay located on passenger inside front wheel well and it works.
Now I have no spark as well...
I've replaced:
1: Coil
I've tested good:
1: Ignition Module ( At Local Supplier)
2: Distributor (Purchased and took back to boneyard
3: ECM (took out and put in my other e150 and it worked).
Is there any coinsidence w/ fuel pump and no spark??
I do have 12V at the coil.
Thanx in advance
cntryboy302
04-05-2007, 07:43 PM
try reversing what you did to get the fuel pump to run and see if you got spark. also, did you try to see if the pump relay was working?
