1998 silverado loosing coolant.....HELP!!
panama-rick
02-22-2007, 06:11 AM
I've got a 1998 Silverado (Z71) and last night I went to change the oil and found a substantially large puddle of coolant on the ground right under the skid plate.
My thoughts are that the coolant was sitting on top of the skid plate and when I drove the truck onto the ramps the coolant flowed off of it.
There is no doubt that the truck is loosing coolant though. I just filled it up last week and when I checked it, the truck was almost dry.
I am pretty sure the leak is right above this skid plate somewhere but I could not find it last night.
I guess I was just wondering if any of you have encountered this and what the problem ended up being in the end.
Thanks in advance for any help
Rick
fordfan1000
02-22-2007, 06:39 AM
Most likely a water pump.Get an inspection mirror and check right under the pump after a short road test.
panama-rick
02-22-2007, 07:29 AM
OK, I will check this tonight. I have been doing a bit of researching and I have found that some guys have thier intake manafold leak also, does this sound right??
If it happens to be the water pump, I have never replaced one, is this something that I should tackle if I am moderately mechanically inclined or should I just bring it in?
panama-rick
02-22-2007, 10:03 AM
It is the water pump. Right where the fan shaft comes into it. Any info or instructions on how to replace this? (Or links)
skipr
03-01-2007, 10:53 PM
It's very easy to replace. the inlet and outlet bolts, a few hoses, the pulley. That's about it. There should be a little hole in the shaft housing, this is to let you know your bearing is worn out, by letting water pass the bearing causing a visible leak.
