89 Grand Prix Cooling issues
GrandPrixLover
02-17-2007, 03:38 PM
Alright, my problem seems simple enough. I have an 89' Grand Prix SE with a 2.8 liter engine. About a month ago the Cooling fan just stopped coming on. So, i replaced a few sensors, still didn't come on. I have now replaced every last sensor that activates the cooling fan and it still dosen't come on. I took it to an auto-repiar shop and they said it was the ECM, so i replaced that and it still won't turn on. Any help would be apreciated. I have checked and the fan itself works.
GregA
02-17-2007, 05:13 PM
Welcome to the forum!
Have you checked or swapped the relay(s) that control the fan?
I believe the PCM just provides a signal (12 volts or ground) to the relay so that the fan will come on. I believe there is a fuse (or two) involved there too.
Let us know what you find.
Take Care,
Take Care,
GrandPrixLover
02-18-2007, 12:32 PM
I have checked all the fuses and fusable links and they are all fine, im not sure where the relay's for the cooling system are. Any ideas?
corning_d3
02-18-2007, 12:43 PM
Just going out on a limb here, but have you directly applied power and ground to the fan to see if it still works?
GrandPrixLover
02-18-2007, 08:57 PM
Yes, i have done that and the fan works.
corning_d3
02-18-2007, 09:07 PM
OK, that's good. What about the continuity of all the wiring? I'd suggest getting a diagram and a connector pinout to test all the circuits. A cheap DVOM is all you need. The only (and safest) way to is by disconnecting the ECM connector(s) before probing around. You'll probably have to anyway to test all the circuits.
GregA
02-19-2007, 12:59 AM
Relays are probably under the hood and should be labeled under the cover.
I agree with corning_d3 - its time to do a little testing of the wiring.
You can TRY to get a wiring diagram at autozone.com (try link below), but I like to have the repair manual.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0e/da/79/0900823d800eda79.jsp
Let us know what you find out.
Almost forgot - do you have AC in that car? And if so - does the fan come on when the AC is switched on (or the defroster)?
Take Care,
Take Care,
richtazz
02-19-2007, 08:46 AM
There should be 2 fan relays in the underhood fuse/relay center. One is for the primary (driver's side) fan, and the other is for the aux (pass side) fan.
